The primary focus of this release is forms. Forms are by no means complete, but quite a lot has been implemented, including more than half of object types. In earlier versions of Panorama the form editor was very dialog heavy, but so far this new version has no dialogs at all. Instead, objects are manipulated with a series of non-modal inspector palettes.
Another change is that this version doesn’t have a bunch of different tools – mouse always acts as a pointer tool for selection. New objects are created by dragging them from the Object Library (or double clicking on a library item).
This version will import forms from existing Panorama databases. Some Panorama 6 object types aren’t supported yet, these objects should be imported as rectangles (this wasn’t extensively tested, however).
One big change you may notice is the way procedures are handled. In previous versions you could select a procedure associated with an object with a pop-up menu. In this new version, you can type any procedure you want into any object. This is sort of like each object having an execute statement associated with it. If you want to use a regular procedure, use the call statement (when importing objects from Panorama 6 the call statement is generated for you automatically.
There are a number of minor enhancements to many objects, including Text Editor, Text Display, even Groups (which now have two different elastic modes for resizing the group’s subobjects).
Many user interface items (buttons, pop-up menus) are in some ways more limited than in previous versions. In this new version the style of interface items is limited to standard OS X appearances. If you want to make a user interface that looks like a standard OS X control, your life will be easier. However, all of the non-standard styles have been removed.
There are currently three completely new objects – polygons, stars and the exciting new Web Browser Object. The Web Browser object will be enhanced later, I believe that Panorama programmers will be able to run JavaScripts within a browser object and probably will be able to access the DOM.
##Missing Features##
There are plenty of missing features, and some known bugs. To save time all around, here is a partial list:
- When resizing an object, Shift key does not constrain to vertical/horizontal dragging.
- Holding down the S key doesn’t expand object handles.
- Holding down the Space Bar doesn’t allow you to start marquee drag on top of an object.
- Double clicking an object doesn’t select objects inside
- Escape key doesn’t toggle graphics mode
- Editing a Text Label object doesn’t work correctly if alignment is center or right.
- Procedure Inspection Panel needs cosmetic work, and better error handling
- No procedure or formula help
- Missing object types, including Flash Art, Pictures, Sticky Push Buttons, Super Matrix, Scrolling List, Tiles, Auto Grow, Word Processor, Charts and more
- No View-As-List Forms
- No reports or printing
- Zooming works, but needs a different UI
- Can’t change ruler dimensions
- Split views (palettes, object library) can’t be brought back after collapsing to zero width/height
- Split view should not change width when window changes width
- No grid or guides
- No auto-spacing dialog
- No form background color
##Documentation Changes##
As you can see, the look of the on-line documentation has been improved.
Graphic Design Mode features have been mostly, but not completely, documented. However, there are no screen shots or movies. These will be added later.
- Aligning Objects -- so that two or more object edges are made even with each other.
- Data Button Object -- is used to create checkboxes and radio buttons.
- decodebase64( -- The decodebase64( function decodes data using Base64.
- degree -- The degree statement tells Panorama that all angles input to and calculated in trigonometric functions are in degrees rather than radians.
- Duplicating Objects -- to make copies of one or more objects.
- encodebase64( -- The encodebase64( function encodes data using Base64.
- Grouping Objects -- allows you to manipulate multiple objects as if they were a single object.
- Line Object -- draws a line within a form.
- Popup Menu Button Object -- is used to create popup menus anywhere on a form.
- Push Button Object -- triggers a procedure when it is pushed.
- radian -- The radian statement tells Panorama that all angles in trigonometric functions should be calculated using radians rather than degrees.
- Smart Resize -- adjusts the sizes and locations of the other selected objects to match the change of one object.
- Text Display Object -- is used to display text using a formula.
- Text Editor Object -- is used to edit text in a field or variable.
- clipboard( -- The clipboard( function returns whatever text is currently on the computer's clipboard.
- graphicsmode -- The graphicsmode statement switches a form into graphics mode.
- info("defaultdatepattern") -- The info("defaultdatepattern") function returns the default date pattern used for displaying dates.
- Oval Object -- draws an oval or circle within a form.
- Rectangle Object -- draws a rectangle or square within a form.
- Rounded Rectangle Object -- draws a rectangle with round corners within a form.
- scrapcalc -- The scrapcalc statement calculates a formula and stores the result in the clipboard. (Note: The same effect can be achieved by putting the word clipboard on the left side of an assignment.)
- selectallobjects -- The selectallobjects statement selects all the graphic objects in the current form.
- selectnoobjects -- The selectnoobjects statement unselects all the graphic objects in the current form.
- showvariables -- The showvariables statement forces Panorama to update the display of one or more variables on every form in the active database.
- degrees2radians( -- The degrees2radians( function converts an angle from degrees to radians.
- Forms -- display data with a customizable graphic layout.
- info("angleunits") -- The info("angleunits") function returns the current angular measurement units.
- info("texteditortrigger") -- The info("texteditortrigger") function returns the reason why a Text Editor object triggered a procedure.
- Object Library -- is used to create new objects in a form.
- radians2degrees( -- The radians2degrees( function converts an angle from radians to degrees.
- Star Object -- draws a star within a form.
