This beta release includes two bug fixes, there are no new features:
[ProcedureStack isProcedureRunning]
method had been modified for use in determining whether or not user interface items (menus, etc.) should be disabled because a procedure was running. However, these changes broke some of the other code that called that method. A new method [ProcedureStack isProcedureActuallyRunning]
was created with the original code, and 14 methods were switched to use this instead of isProcedureRunning. In addition to fixing the problems in the Find/Select dialog, it may possibly have fixed other problems that had not been detected yet.info("windownames")
etc.) if a window has an unassigned title.
