This release contains a handful of bug fixes.
The Maximum command now works correctly if all numeric values are negative.
When in a form, removed keyboard equivalents for Move Record Up/Move Record Down. This allows Command-Up/Command-Down to move the insertion point in the text, which is what is expected. These shortcuts still work in the data sheet to move the current record.
Panorama now automatically closes the current Text Editing session (in a form) if you perform an operation that will move the database from the current record, including add record, insert record, delete record, find next/previous, sort, group, etc.
Added new statement FixSuperDates, and updated documentation to indicate that this must be used when upgrading a database that contains SuperDates from Panorama 6 to Panorama X.
The Morph Field Dialog now always displays an error notification if you try to use it on a binary field, even if Do Not Disturb is enabled.
The Running Total command now handles summary records exactly the same way that Panorama 6 did. Note: This isn’t really correct for multi-level summaries, nor was it ever documented to work for multi-level summaries, or any summaries.
The Panorama Video Training wizard now defaults to “All Skill Levels” instead of “Beginner” when first opened.
Minor documentation corrections.
- fixsuperdates -- The fixsuperdates statement fixes Panorama 6 SuperDates in current field.
