This release contains minor bug fixes.
- The autofieldwidth statement now works correctly even if one or more fields are hidden.
- Added eulersnumber( function as a synonym for eulersconstant(. Also modified the documentation to clarify that this function returns Euler’s number, not Euler’s constant. However, since existing code may rely on the eulersconstant( function returning Euler’s number, it still does. There is no function that returns Euler’s constant.
- Fixed hanging synchronization progress window when opening a shared database.
- Documentation corrections from Robert Ameeti, Steve Venegas, Craig McPherson.
