This release includes a handful of bug fixes.
- The File menu now correctly includes the Duplicate command (or Save As if the Option key is pressed).
- When triggering a procedure from a form object, Panorama now automatically runs the code using the database associated with that form object (not any secret window that may happen to be open).
- The Generation History dialog is now always scrolled to 0,0 (not sometimes shifted over to the left).
- Fixed the Text Display AutoScrollToBottom option so that it is independent of the SelectableText option. (In any database saved with b34, the AutoScrollToBottom option will be set if the SelectableText option was set. This will have to be fixed manually by the user after upgrading to b35 or later.)
- Documentation corrections from Laurence Veinott, Peter Newble, Craig McPherson.
- Panorama X now compiled with Xcode 13 (Apple no longer supports notarization when using Xcode 12). This should not affect compatibility with older versions of OS X, Panorama X is still compatible back to 10.12 Sierra.
