This release primarily includes changes made in preparation for the Text Lists and Matrixes class (part of the Panorama X Developer Certification Course).
Added new List/Matrix command in the Construct menu, and also the ConstructListMatrix statement. This makes it super easy to create and modify a wide variety of Text List and Matrix objects.
New dragarrayorder and dragwithinmatrix statements facilitate dragging (and potentially reoordering) items within a Text List or Matrix object.
Text List objects now have a Resizable Columns option (with some limitations).
Columns in the Find/Select dialog can now be temporarily resized.
New matrixclick function automatically triggers code in an object in the matrix frame when it is clicked within a matrix.
New [info(“matrixclickedobjectid”][] function can be used when handling a click on a Matrix object. If the user clicked on an object within the frame, this function returns the object id of that object.
The info(“clickedobjectid”), info(“clickedobjectname”) and info(“buttonrectangle”) functions now work with Text List and Matrix objects.
New Text List feature – if all field specifications begin with @ and the formula is missing, the appropriate formula will be generated automatically. The formula will also be generated automatically for or @ (but again, only if the formula is missing).
Changed the default selection color for Matrixes and View-as-List Forms to use light instead of dark blue (actually, it uses the default system text selection color, instead of the default selected control color).
Changed defaults for new Matrix objects to 1 column, fixed height 36 point rows, vertical scroll bar, bezel border, alternating colors, hilite selection, gray color (for cell borders). Also when you ask a Matrix object to create a frame object, it now creates a Matrix Frame report tile, instead of a rectangle, and no object names are generated. Fixed location of automatically generated Matrix Frame object.
Reduce minimum size of form in graphics mode to 450h by 600w (if smaller than this it will zoom).
Nineteen assorted fixes to Text List and Matrix objects that are too minor to list separately.
- arrayrelocate -- The arrayrelocate statement moves one or more items in a text array to a new position.
- constructlistmatrix -- The constructlistmatrix statement creates a text list or matrix in the current form.
- dragarrayorder -- The dragarrayorder statement tracks dragging of a cell within a Matrix or Text List object, then reorders the array associated with that object accordingly.
- dragwithinmatrix -- The dragwithinmatrix statement tracks dragging of a cell within a Matrix or Text List object.
- info("matrixclickedobjectid") -- The info("matrixclickedobjectid") function returns the object id of the object in a matrix that was clicked on (or zero if none).
- matrixclick -- The matrixclick statement will run the code belonging to an object that was clicked within a matrix frame.
- Numbers -- Working with numeric values in a formula, and converting between numbers and text.
- formoptionsblueprintsheet -- The formoptionsblueprintsheet statement opens a dialog sheet to edit the blueprint of the current form options.
