This version makes Panorama X compatible with macOS 15 Sequoia, and also includes the changes listed below.
- Panorama no longer allows the user to click to change window order while a procedure is running.
- When opening a shared database Panorama prevents window switching or running other procedures until synchronization is finished.
- Implemented the webshare statement (brought over from Panorama 6.0).
- New nanzero( and nanerror( functions provide additional flexibility in dealing with invalid floating point values.
- The View and Action menus now work correctly with form and procedure names that contain the } character.
- Double chevron notation now works in the formulavalue function and statement, and formulacalc. (This means that it now works correctly in the Formula Workshop, and dialogs like Morph > Formula Fill.)
- The selectrelated and selectrecordsrelatedto statements now work even if the specified relation options aren’t all in upper case.
- The BinaryDataBuild( function now works correctly with double chevron notation.
- Fixed pattern( function for scientific/engineering notation with small numbers and negative numbers.
- Creating a new database with an imported text file with field names now strips off any blank lines from the beginning and end of imported data.
- The PrintToPDF statement COPIES option now works correctly if default printer specified.
- Updated Zip Code information with July 2024 data from US post office.
- Panorama now now automatically opens the Site License window if you are not logged in.
- Oops. Misspelled “dictionary” in seven error messages!! Now fixed.
- Documentation of info(“guid”) function now mentions UUID as well as GUID.
- Documentation corrections from David Thompson, Peter Newble, James Cook, Robert Ameeti, David Scott, Robert McGarey, Bruce De Benedictis, Paul Overby
