This is a minor release with some bug fixes, small enhancements, and filling in some minor missing functionality from previous versions of Panorama.
General fixes to the Favorites wizard, including allowing you to drag open databases to the wizard, and displaying properly when there are no favorites.
View Organizer wizard now has a dialog sheet that summarizes all code errors in the current database (or at least the first error in each procedure).
Added Print One Record to File menu.
Added printing related statements: print, printonerecord, printusingform and pagesetup.
Implemented about twenty “legacy” statements and functions. Most of these don’t provide any actual new functionality in Panorama X, but make it easier to convert existing Panorama 6 databases, especially if they contain really old code.
Added statements for changing the stacking (z-order) of form objects (bringtofront, sendtoback, etc.)
Vertical and horizontal lines now draw correctly.
clipboard()= assignments now work.
Data sheet was not printing the last page of the sheet, now it does.
The rest of this page enumerates documentation changes in this release (mostly statements and functions).
- bringforward -- The bringforward statement brings the selected form objects one layer towards the front.
- bringtofront -- The bringtofront statement brings the selected form objects to the front.
- favoritedatabasedialog -- The favoritedatabasedialog statement opens the standard Favorite Databases dialog.
- sendbackward -- The sendbackward statement sends the selected form objects one layer towards the back.
- sendtoback -- The sendtoback statement sends the selected form objects to the back.
- expressionstacksize -- The expressionstacksize statement does nothing.
- extendedexpressionstack -- The extendedexpressionstack statement does nothing.
- formulabuffer -- The formulabuffer statement does nothing.
- growl -- The growl statement displays a notification.
- growlmessage -- The growlmessage statement displays a notification.
- info("expressionstacksize") -- The info("expressionstacksize") function returns the fake size of expression stack.
- info("formulabuffer") -- The info("formulabuffer") function returns the fake size of the formula buffer.
- info("formulamemory") -- The info("formulamemory") function function returns the fake size of the formula memory.
- loadurl -- The loadurl statement loads a resource from the internet.
- normalexpressionstack -- The normalexpressionstack statement does nothing.
- posturl -- The posturl statement loads a resource from the internet, with form data.
- printusingform -- The printusingform statement allows the current database to be printed using a different form than the one currently being displayed.
- updateballoonlocations -- The updateballoonlocations statement does nothing.
- getautonumber -- The getautonumber statement returns the automatically generated number for the next record that will be added to the database.
- getmaxwindow -- The getmaxwindow statement retrieves the position and size of the largest possible window on the main screen.
- getproceduretext -- The getproceduretext statement gets the contents (source) of a procedure and places it in a variable.
- getwindow -- The getwindow statement retrieves the position and size of the current window.
- pagesetup -- The pagesetup statement displays the page setup dialog.
- print -- The print statement prints the database.
- printonerecord -- The printonerecord statement prints the the currently active record.
- setautonumber -- The setautonumber statement changes the automatically generated number for the next record that will be added to database. This allows you to generate numbers out of sequence, or to start the sequence at a specific value.
- setreportcolumns -- The setreportcolumns statement allows a procedure to control the number of columns of a report, and the direction (across or down).
- setwindow -- The setwindow statement specifies the dimensions (size and location) of the next window that is opened (with openform, opensheet, openprocedure etc.).
- uniqueid( -- The uniqueid( function generates ID codes with a text root and a numeric suffix (for example `Jeff261`).
- windowbox -- The windowbox statement specifies the dimensions (size and location) of the next window that is opened (with openform, opensheet, openprocedure etc.).
