The changes in this beta release include:
- Panorama Video Training now allows ProVUE to update the list of videos at any time (before the list could only be changed by releasing a new version of Panorama). This will be used to post session recordings during the upcoming courses.
- New Live Course Calendar window facilitates scheduling of Zoom sessions (Help menu).
- Through an oversight, the OPENWEBMAP statement was not brought over from Panorama 6, now it has been.
- Hack to make sure that in the Database Options>Relation panel, the key option checkboxes are always visible, even if the dialog opens to this panel. To make this work, had to remove the bezel background from the key options box and just leave no background (hence white). When switching from another panel, the background is correctly set to the nice looking bezel. Hopefully someday the underlying problem can be resolved and this hack removed.
- The GetCityStateZip statement no longer gets confused if the address ends with US (or any variation of the spelling of the US) or Canada.
- Tweaked server usage code to make it more accurate. Should no longer count downloading static files as web usage. Ping and Snapshot quries are no longer counted as usage. Inbound data is now counted more accurately (counts the actual text, instead of the raw dictionary)
- New functions for working with time zones – converttimezone(, daylightsavingstimeoffset(, nextdaylightsavingstimetransition(, info(“localtimezone”), info(“timezones”), info(“timezoneabbreviations”), timezoneabbreviation( and timezonename(. Also, “local” is now allowed to specify the local time zone (in addition to “”).
- Now must be logged in to an account to run any beta version of Panorama X.
