This version includes a critical update that allows Panorama to communicate with the provue.com server. You may not see an immediate problem if you continue to use older versions, but you will not be able to use the Site License window, and you will eventually get messages that you need to connect to provue.com. The only way to make that connection is to install and use the b30 version, so we strongly urge that all users install this new version immediately.
