timerexists(
TIMER
The timerexists( function checks to see whether a timer exists.
This function has one  parameter:
timer – name of the timer to check.
- info("computername") -- returns the name of the computer (as set up in the System Preferences Sharing panel).
- info("timers") -- returns a carriage return separated list of all active timers.
- stoptimer -- stops and deletes a timer that was set up with the StartTimer statement.
- Timer Workshop -- provides a tool for monitoring timers and testing timer configurations.
- timerinfo( -- returns a dictionary that contains all of the properties of a timer.
- Timers -- executing recurring periodic background code at fixed intervals.
- Understanding the Run Loop -- explanation of how Panorama code interacts with the run loop to respond to mouse clicks, keyboard presses, display updates and other events that require attention.
- wait -- pauses the program for a specified period of time.
