callingprocedure(
The callingprocedure( function returns the name of the procedure that called this procedure as a subroutine, if any.
If a procedure was called as a subroutine by another procedure, this function will return the name of the calling procedure.
This example shows how a procedure can be set up to work as a standalone procedure or as a subroutine. If the procedure is called as a subroutine it gets the start value from the calling procedure, but if it is used standalone it will prompt the user to enter the start value.
local start
if callingprocedure() <> ""
start= parameter( 1)
else
start=""
gettext "Start: ",start
... rest of subroutine
In this example it doesn’t matter what the name of the calling procedure is, but that information is available if necessary.
- quit -- quits Panorama.
