info("computername")
The info(“computername”) function returns the name of the computer (as set up in the System Preferences Sharing panel).
This function returns the name of the computer (as set up in the System Preferences Sharing panel).
info("computername") ☞ Bob's MacBook Pro
- info("computerserialnumber") -- returns the computer's serial number.
- info("localhostname") -- returns the computer's local host name.
- info("unixgroupid") -- returns the UNIX group ID of the current user.
- info("unixuserid") -- returns the UNIX user ID of the current user.
- Timer Workshop -- provides a tool for monitoring timers and testing timer configurations.
- timerexists( -- checks to see whether a timer exists.
- Timers -- executing recurring periodic background code at fixed intervals.
- Understanding the Run Loop -- explanation of how Panorama code interacts with the run loop to respond to mouse clicks, keyboard presses, display updates and other events that require attention.
- wait -- pauses the program for a specified period of time.
