callwithindatabase(
The callwithindatabase( function returns true if the current procedure was called by another procedure in the same database, false if it was called by a procedure in another database.
This example shows how to make a “private” procedure that can be called by other procedures in the same database but not by procedures in other databases.
if  callwithindatabase() = false()
    return
... rest of procedure
An alternative would be to replace the return statement with a returnerror statement.
