callwithin(
DATABASE
PROCEDURE
LABEL
PARAMETERS
The callwithin( function allows a “mini-procedure” to be called as a subroutine within a formula and return a result.
database – is the database containing the procedure you want to run, or "" to use a procedure within the current database.
procedure – is the name of the procedure you want to run, or "" to call within the current procedure.
label – identifies the beginning of the mini-subroutine. (The end of the mini-subroutine is defined by a return statement or the end of the procedure.) A label is a unique series of letters and numbers that identifies a location within the procedure. The label must start with a letter, may not contain any spaces or punctuation except for ., _ and %, and must always end with a colon. The colon is not actually part of the label, it simply identifies the series of letters and numbers as a label instead of a field or variable..
parameters – is a list of parameters to be passed to the subroutine. This list is optional, you don’t have to pass any parameters if you don’t need to. See parameter( and setparameter for more information on accessing parameters within a subroutine.
The callwithin( function allows a “mini-procedure” within a procedure to be called as a subroutine within a formula and return a result. It’s basically a combination of the call( function and shortcall statement. The “mini-procedure” must contain a functionvalue statement that tells Panorama what value to return from the function. (The “mini-procedure” may contain multiple functionvalue statements, in which case the function will return the value of the last functionvalue statement executed.)
The callwithin( function allow you to perform procedure statements anywhere a formula is allowed, including in form objects, formulafill, etc. There are some significant restrictions that the procedure called by this function must follow, see the call( function for details.
The callwithin( function allows you to supply one or more parameters to be passed to the subroutine (each parameter must be separated by a comma). When using the callwithin( function the parameters are listed after the database, procedure name and label name, like this:
callwithin(database,procedure,label,parameter1,parameter2,parameter3, ... parameterN)
The specified procedure (subroutine) can access the parameters with the parameter( function, or change the value of a parameter with the setparameter statement.
Handling Errors
If there is a syntax error in the subroutine (misspelled command, unexpected formula operator, etc.) the function will return an error message describing the problem instead of the calculated value (since there is a syntax error, it cannot even try to run the program.
If there is a run-time error in the subroutine (for example a missing variable, incorrect data type, etc.) the function will also return an error message describing the problem. Or you can also use the if error, try/catch or onerror statements (see Error Handling) to trap the error yourself and take appropriate action without returning an error. You can even combine the functionvalue statement with the error( function to return your own custom error message.
Error Messages
Procedure called by callwithin( function does not return a value (you must add the functionvalue statement) – The procedure that is called must include a functionvalue statement. If there is a functionvalue statement and you still see this error, the functionvalue is not being executed – check the logic of the procedure.
