- changetimer -- The changetimer statement modifies a repeating task that will be performed periodically when Panorama is not otherwise busy.
- info("timerinfo") -- The info("timerinfo") function returns a dictionary that contains all of the properties of the currently running timer.
- info("timers") -- The info("timers") function returns a carriage return separated list of all active timers.
- starttimer -- The starttimer statement sets up and starts a repeating task that will be performed periodically when Panorama is not otherwise busy.
- stoptimer -- The stoptimer statement stops and deletes a timer that was set up with the StartTimer statement.
- timerexists( -- The timerexists( function checks to see whether a timer exists.
- timerinfo( -- The timerinfo( function returns a dictionary that contains all of the properties of a timer.
- info("computername") -- returns the name of the computer (as set up in the System Preferences Sharing panel).
- info("timers") -- returns a carriage return separated list of all active timers.
- stoptimer -- stops and deletes a timer that was set up with the StartTimer statement.
- Timer Workshop -- provides a tool for monitoring timers and testing timer configurations.
- timerexists( -- checks to see whether a timer exists.
- timerinfo( -- returns a dictionary that contains all of the properties of a timer.
- Understanding the Run Loop -- explanation of how Panorama code interacts with the run loop to respond to mouse clicks, keyboard presses, display updates and other events that require attention.
- wait -- pauses the program for a specified period of time.
