error(
MESSAGE
The error( function returns an error with the specified message.
message – The error message to return.
This function generates an error. It is usually used with the ?( or switch( functions, like this:
?(Price>0,Price,error("Negative or zero price is not allowed"))
Note that this function is not generating a text value, it is generating an error. This means, for example, that in this case a negative price would stop a procedure that contained this formula (unless the procedure used error trapping).
- ?( -- allows a formula to make a true/false, yes/no decision.
- catcherror( -- evaluates an expression, but suppresses any error generated by that expression.
- errortext( -- evaluates an expression, but returns only the error message generated (if any).
- switch( -- chooses from a list of values.
10.0 | New | New in this version |
