errortext(
EXPRESSION
The errortext( function evaluates an expression, but returns only the error message generated (if any).
expression – expression that may generate an error message.
This function allows you to to determine the error message of an expression. Panorama uses this for things like reporting errors in the Find/Select dialog. If the expression works without an error, this function returns ""
. But if there is an error, the error message is returned.
errortext(2) ☞ ""
errortext(2+a) ☞ "Field or variable [a] does not exist"
- catcherror( -- evaluates an expression, but suppresses any error generated by that expression.
- error( -- returns an error with the specified message.
