float(
VALUE
The float( function converts a fixed point number to a floating point number.
value – is the value you want to convert to a floating point number. You may use any numeric value, for example 1, -7, 9823 etc.
This function converts any input value into a floating point number.
float(3) ☞ 3.0000
float("3") ☞ 3.0000
float("abc") ☞ 0.0000
float(3.5) ☞ 3.5000
As the examples show, this function accepts any type of value, including integers, text, and even floating point numbers (in which case the function has no effect).
- - -- subtracts the numeric value on the right from the numeric value on the left.
- * -- multiplies the numeric value on the left by the numeric value on the right.
- \ -- performs integer division.
- ^ -- raises a number to a power.
- + -- works differently depending on the type of operands used with it.
If both operands are numeric, it does numerical addition.
If either operand is text the + operator concatenates (joins together) the two operands.
- abs( -- calculates the absolute value of a number.
- and -- returns true if both operands are true.
- arccos( -- calculates the inverse cosine of a numeric value.
- arccosh( -- calculates the inverse hyperbolic cosine of a numeric value.
- arcsin( -- calculates the inverse sine of a numeric value.
- arcsinh( -- calculates the inverse hyperbolic sine of a numeric value.
- arctan( -- calculates the inverse tangent of a numeric value.
- arctanh( -- calculates the inverse hyperbolic tangent of a numeric value.
- bit( -- converts a bit number (1 to 64) into a number (1, 2, 4, 8, 16, etc.)
- ceil( -- converts a number to an integer, truncating toward positive infinity.
- chart( -- converts a table of data into an HTML page with a chart (bar, line, pie, etc.).
- cos( -- calculates the cosine of an angle.
- cosh( -- calculates the hyperbolic cosine of a numeric value.
- count( -- counts all non-empty instances of a line item field in the current record.
- crosstab( -- converts information in a database into a crosstab table (tab delimited text).
- degrees2radians( -- converts an angle from degrees to radians.
- degreestoradians( -- converts an angle from degrees into radians
- divzero( -- divides two numbers, returns zero if denominator is zero.
- divzeroerror( -- divides two numbers, returns an error if the denominator is zero.
- eulersnumber( -- returns the value of Euler's number.
- fact( -- computes the factorial of a value.
- fix( -- converts a number to an integer, truncating toward zero.
- fixed -- converts a floating point number to fixed point.
- fv( -- (short for *future value*) calculates the future value of an investment.
- getbit( -- returns the value of a bit within a number.
- groupseq( -- returns the sequence number within a summary level.
- int( -- converts a number to an integer, truncating toward negative infinity.
- latlongdistance( -- calculates the distance between two points on the earth (or any other sphere).
- log( -- computes the natural logarithm (base e ) of a value.
- log10( -- computes the common logarithm (base 10) of a value.
- makeinteger( -- makes a random integer with up to the specified # of digits (may be less).
- mod -- computes the remainder (modulo) after integer division.
- monthmath( -- takes a date and computes the date that is one or more months before or after the original date.
- not -- reverses a boolean value.
- not( -- reverses a Boolean value
- numsandwich( -- is similar to the sandwich function, but for numbers. If the value is zero the result is zero, but if the value is not zero the result is the value plus the extra.
- onescomplement( -- returns the one's complement of a 64 bit number (all bits are reversed)
- or -- returns true if either operand is true, or false if both are false.
- pi( -- returns the value of pi
- pmt( -- (short for *payment*) calculates the periodic payment required to pay off a loan.
- pv( -- (short for *present value*) calculates the present value of an income or debit stream of payments.
- radians2degrees( -- converts an angle from radians to degrees.
- radianstodegrees( -- converts an angle from radians to degrees.
- randominteger( -- generates a random integer between the starting and ending values.
- rnd( -- generates a random number between 0 and 1.
- round( -- rounds a number to a specified increment.
- setbit( -- sets or clears one bit within a number, without disturbing any of the other bits.
- sin( -- calculates the sine of an angle.
- sinh( -- calculates the hyperbolic sine of a numeric value.
- sqr( -- calculates the square root of a value.
- sum( -- adds up all instances of a line item field in the current record.
- tan( -- calculates the tangent of an angle.
- tanh( -- calculates the hyperbolic tangent of a numeric value.
- xor -- returns true if one of the two parameters is true, false if neither or both are true.
