VALUE
not
The not operator reverses a boolean value.
This operator has one parameter:
value – A Boolean (integer) value.
The not operator reverses a Boolean value – true becomes false, false becomes true. Not is a unary operator, so there is no parameter on the left, only a single parameter on the right.
not true() ☞ false
not false() ☞ true
not 1=1 ☞ false
not "green"="blue" ☞ true
Note for C Programmers: The not operator is equivalent to the ~ operator in C. It actually performs a ones-complement on the value, so you can use this operator if you need to “flip the bits” in a numeric value.
- and -- returns true if both operands are true.
- false( -- returns false.
- not( -- reverses a Boolean value
- or -- returns true if either operand is true, or false if both are false.
- switch( -- chooses from a list of values.
- true( -- returns true.
- xor -- returns true if one of the two parameters is true, false if neither or both are true.
| 10.0 | Updated | Carried over from Panorama 6.0, but you are no longer required to put parentheses around the formula in a procedure if it begins with the *not* operator. |
