The bit( function converts a bit number (1 to 64) into a number (1, 2, 4, 8, 16, etc.)
This function has one parameter:bit – bit number from 1 to 64.
This function converts a bit number (1 to 64) into a number (1, 2, 4, 8, 16, etc.)
bit(1) ☞ 1
bit(2) ☞ 2
bit(3) ☞ 4
bit(4) ☞ 8
bit(12) ☞ 2048
bit(31) ☞ 1073741824
bit(50) ☞ 562949953421312
?(bitnum=64,hex("8000000000000000"),fix(2^(bitnum-1)))
| Version | Status | Notes |
| 10.0 | Updated | Carried over from Panorama 6.0, but now supports up to 64 bits (instead of 32). |
