VALUE1
or
VALUE2
The or operator returns true if either operand is true, or false if both are false.
value1 – The first Boolean value.
value2 – The second Boolean value.
The or operator combines two Boolean values by or-ing them together. This example checks to see if a transaction is being paid for with a credit card.
if PaymentMethod="Visa" or PaymentMethod="MasterCard"
Terms="Credit Card"
The result is true if the payment method is Visa or MasterCard.
Note that each side of the or operator must contain a complete formula. The formula below looks correct in English, but will not work in Panorama:
PaymentMethod="Visa" or "MasterCard" ☞ Error
Here is the correct formula:
Note: The Boolean values true and false are actually integer (numeric) values -1 and 0.
Note: If you are a “C” programmer, Panorama’s or operator is equivalent to C’s || operator. (In fact, Panorama will allow you to use || if you wish, however, you should avoid this if your formula also uses the pipe character for text constants like this: ||this is a constant||.)
Error Messages
Cannot OR a number with text. – Both operands must be numbers. If either operand contains a text value, an error occurs.
- and -- returns true if both operands are true.
- false( -- returns false.
- not -- reverses a boolean value.
- not( -- reverses a Boolean value
- switch( -- chooses from a list of values.
- true( -- returns true.
- xor -- returns true if one of the two parameters is true, false if neither or both are true.
