latlongdistance(
LATITUDE1
LONGITUDE1
LATITUDE2
LONGITUDE2
UNITS/RADIUS
The latlongdistance( function calculates the distance between two points on the earth (or any other sphere).
This function has five parameters:
latitude1 – the latitude of the first point, expressed in decimal degrees (for example 34.1614).
longitude1 – the longitude of the first point, expressed in decimal degrees (for example -118.0054).
latitude2 – the latitude of the second point.
longitude2 – the longitude of the second point.
units/radius – the units for this calculation. This parameter is optional – if omitted, the default is miles. The distance can be calulated in miles, kilometers or nautical miles (and the abbreviations mile, kilo, km and nm are also accepted). This parameter can also be used to spedify the radius of the earth or any other sphere.
This function calculates the distance between two points on the earth (or any other sphere). The points 34,-118 and 35,-118 are about 69 miles apart.
latlongdistance(34,-118,35,-118) ☞ 69.097585
The distance is normally calculated in miles, but you can also specify kilometers or nautical miles.
latlongdistance(34,-118,35,-118,"miles") ☞ 69.097585
latlongdistance(34,-118,35,-118,"kilometers") ☞ 111.194927
latlongdistance(34,-118,35,-118,"nm") ☞ 60.039326.
The final parameter can also be used to specify the radius of the earch (or other sphere). In that case, the units can be whatever you want – the results will be in the same units. This example calculates a distance between two objects on the earth in meters (as noted below, this calculation isn’t really accurate to the meter, much less a fraction of a millimeter).
latlongdistance(34,-118,35,-118,6378100) ☞ 111318.845021
This example calculates a distance on the moon in kilometers (the radius of the moon is 1,737 km).
latlongdistance(-118,34,-118,35,1737) ☞ 30.316369
Accuracy
This function uses the Haversine formula to calculate distances, which is well conditioned for all distances except for those close to 180° (see Great Circle Distance). The function does assume that the Earth is a perfect sphere.
