The sqr( function calculates the square root of a value.
This function has one parameter:value – This parameter must be a positive numeric value.
This function calculates the square root of a positive number. The graph below shows the result of the square root function given input values from 0 to +8.
The square root of a negative number is a complex number (see Wikipedia) which is beyond the scope of Panorama.
Error Messages
Floating point error – The square root of values 0 or less (negative numbers) is undefined. If you attempt to calculate the square root of such a number, a floating point error will occur.
