VALUE1
VALUE2
The - operator subtracts the numeric value on the right from the numeric value on the left.
value1 – The first numeric value.
value2 – The second numeric value.
This operator performs subtraction just like you learned in grade school. You can subtract integers:
5-2 ☞ 3
And you can also subtract floating point values:
5.75-2.5 ☞ 3.25
Error Messages
Cannot subtract a number from text (or text from a number) – Both operands must be numbers. If either or both operands are text values you must use the val( function to convert the value to a number before subtracting.
- * -- multiplies the numeric value on the left by the numeric value on the right.
- \ -- performs integer division.
- ^ -- raises a number to a power.
- abs( -- calculates the absolute value of a number.
- ceil( -- converts a number to an integer, truncating toward positive infinity.
- divzero( -- divides two numbers, returns zero if denominator is zero.
- divzeroerror( -- divides two numbers, returns an error if the denominator is zero.
- fix( -- converts a number to an integer, truncating toward zero.
- fixed -- converts a floating point number to fixed point.
- float( -- converts a fixed point number to a floating point number.
- infinity( -- returns infinity.
- int( -- converts a number to an integer, truncating toward negative infinity.
- mod -- computes the remainder (modulo) after integer division.
- nan( -- checks to see if a numeric value is invalid.
- nanerror( -- converts invalid numeric values into an error.
- randominteger( -- generates a random integer between the starting and ending values.
- rnd( -- generates a random number between 0 and 1.
- round( -- rounds a number to a specified increment.
