VALUE1
and
VALUE2
The and operator returns true if both operands are true.
value1 – The first Boolean value.
value2 – The second Boolean value.
The and operator combines two Boolean values by anding them together. In this example the value in the Age field or variable must be a number.
if Age >= 13 and Age<20
Status="Teenager"
The result is true if the person is 13 or older and if the person is less than 20 years old.
Note: The Boolean values true and false are actually integer (numeric) values -1 and 0 respectively.
Note: If you are a “C” programmer, Panorama’s and operator is equivalent to C’s && operator. (In fact, Panorama will allow you to use && if you wish.)
Error Messages
Cannot AND a number with text. – Both operands must be numbers. If either operand contains a text value, an error occurs.
- beginswith -- returns true if the value on the left starts with
the value on the right, false if it doesn't.
- contains -- returns true if the value on the left contains
- endswith -- returns true if the value on the left ends with
- false( -- returns false.
- not -- reverses a boolean value.
- not( -- reverses a Boolean value
- notcontains -- returns true if the value on the left does not contain
the value on the right, false if it does.
- or -- returns true if either operand is true, or false if both are false.
- switch( -- chooses from a list of values.
- true( -- returns true.
- xor -- returns true if one of the two parameters is true, false if neither or both are true.
