not(
VALUE
The not( function reverses a Boolean value
value – a Boolean (integer) value.
This function reverses a Boolean value.
not(true()) ☞ false
not(false()) ☞ true
not(1=1) ☞ false
not("green"="blue") ☞ true
Note for C Programmers: The not( function is equivalent to the ~ operator in C. It actually performs a ones-complement on the value, so you can use this function if you need to “flip the bits” in a numeric value.
- and -- returns true if both operands are true.
- false( -- returns false.
- not -- reverses a boolean value.
- or -- returns true if either operand is true, or false if both are false.
- switch( -- chooses from a list of values.
- true( -- returns true.
- xor -- returns true if one of the two parameters is true, false if neither or both are true.
10.0 | No Change | Carried over from Panorama 6.0 (however it was not documented). |
