int(
VALUE
The int( function converts a number to an integer, truncating toward negative infinity.
value – is the input value.
The int( function converts a number to an integer, truncating toward negative inifinity. (The ceil( function is similar, but truncates toward positive infinity.)
int(4.5) ☞ 4
int(-4.5) ☞ -5
10.0No ChangeCarried over from Panorama 6.
