fix(
VALUE
The fix( function converts a number to an integer, truncating toward zero.
value – is the input value.
The fix( function converts a number to an integer, truncating toward zero. (The int( function is similar, but truncates toward negative infinity.)
fix(4.5) ☞ 4
fix(-4.5) ☞ -4
