The ceil( function converts a number to an integer, truncating toward positive infinity.
This function has one parameter:value – is the input value.
The ceil( function converts a number to an integer, truncating toward positive inifinity. (The int( function is similar, but truncates toward negative infinity.)
ceil(4.5) ☞ 5
ceil(-4.5) ☞ -4
If the input value is text, the result will be zero.
10.0 | New | New in this version |
