If you need to line up several objects, you can either do it by eye or you can let Panorama do it for you.
To align several objects, first select the objects, then right click on one of the objects and choose Align Objects from the pop-up menu. (You can also choose Align Objects from the Arrange menu.) Then choose the alignment method you need from the submenu.
10.0 | Updated | Carried over from Panorama 6.0, but now uses a menu instead of a dialog. |
