obscuredigits(
CARDNUMBER
CLEARDIGIT
The obscuredigits( function obscures digits in a number (usually a credit card number) with Xs.
cardnumber – the number.
cleardigit – the number of digits on the end that will not be obscured.
This function obscures digits in a number (usually a credit card number) with Xs. The first parameter is the number. The second parameter is the number of characters on the end that will NOT be obscured.
obscuredigits("1234-5678-9876-5432",4) ☞ XXXX-XXXX-XXXX-5432
obscuredigits("1234-5678-9876-5432",7) ☞ XXXX-XXXX-XX76-5432
Panorama also has a more general function for obfuscating all kinds of text, see the obfuscate( function.
- appendluhncheckdigit( -- adds a Luhn check digit to a series of digits.
- obfuscate( -- randomizes the letters and digits in text.
- replacefirst( -- replaces the first occurence of some text with new text.
