info("accessorypanelisopen")
The info(“accessorypanelisopen”) function returns the status of the current window’s accessory panel, if any.
This function returns the status of the current window’s accessory panel, if any. The result is true if the panel is visible, false if it is hidden.
10.0 | New | New in this version |
