updatingwindow(
The updatingwindow( function returns true if in a formula that is being displayed on a form, otherwise false.
This function returns true if in a formula that is being displayed on a form, otherwise false. The primary use for this is in forms that are templates for web forms. Using this function allows a formula (or procedure) to produce a different result depending on whether the result will be displayed on the screen or is being used to generate an HTML page.
Note: This function actually only works with Text Display and Image Display objects.
