wordarray(
DATA
INDEX
The wordarray( function extracts a value from an array of 16 bit words (see Binary Data).
data – binary data containing one or more word (16-bit) values. See Binary Data for more information on this type of data.
index – position of the desired word, starting from 1.
This function extracts a value from an array of words. This is not a Panorama style delimited array but a C style array of 16 bit values. The result is an integer.
wordarray(word(3)+word(12)+word(87),2) ☞ 12
See Binary Data for more information about this type of data.
binaryvalue((thetext)[1+(index-1)*2;2])
10.0 | Updated | Carried over from Panorama 6.0, but since Panorama can no longer treat text as binary data, this function now requires that the first parameter be a binary data value instead of a text value. |
