word(
NUMBER
The word( function converts a number into a single word (2 bytes) of binary data (see Binary Data).
number – is the value that you want to convert into a binary number. This value must be between -65534 and 65535.
This function converts a number from -254 to +255 into a single word (2 bytes) of binary data (see Binary Data).
10.0 | Updated | Carried over from Panorama 6.0, but now returns a binary value instead of a text value. |
