longwordarray(
DATA
INDEX
The longwordarray( function extracts a value from an array of 32 bit longwords (see Binary Data).
data – binary data containing one or more longword (32-bit) values. See Binary Data for more information on this type of data.
index – position of the desired longword, starting from 1.
This function extracts a value from an array of longwords. This is not a Panorama style delimited array but a C style array of 32 bit values. The result is an integer.
longwordarray(longword(3)+longword(12)+longword(87),3) ☞ 87
See Binary Data for more information about this type of data.
binaryvalue((thetext)[1+(index-1)*4;4])
