longlongwordarray(
DATA
INDEX
The longlongwordarray( function extracts a value from an array of 64 bit longlongwords (see Binary Data).
data – binary data containing one or more longlongword (64-bit) values. See Binary Data for more information on this type of data.
index – position of the desired longlongword, starting from 1.
This function extracts a value from an array of longlongwords. This is not a Panorama style delimited array but a C style array of 64 bit values. The result is an integer.
longlongwordarray(longlongword(3948)+longlongword(42098)+longlongword(112),2) ☞ 42098
See Binary Data for more information about this type of data.
binaryvalue((thetext)[1+(index-1)*8;8])
10.0 | Updated | New in this version. |
