longword(
NUMBER
The longword( function converts a number into a 32 bit longword (4 bytes) of binary data (see Binary Data).
number – is the value that you want to convert into a binary number.
This function converts a number into a 32 bit longword (4 bytes) of binary data (see Binary Data).
Error Messages
longword( function requires a numeric parameter. – Only numbers can be converted to binary, not text or other binary data.
| 10.0 | Updated | Carried over from Panorama 6.0, but now returns a binary value instead of a text value. |
