byte(
NUMBER
The byte( function converts a number into a single byte of binary data (see Binary Data).
number – is the value that you want to convert into a binary number. This value must be between -254 and 255.
This function converts a number from -254 to +255 into a single byte of binary data (see Binary Data).
Note: In older (pre-Unicode) versions of Panorama this function was identical to the chr( function, but they are now different. The result of the chr( function is a single character of text (which may be 1, 2, 3 or more bytes long), while the result of the byte( function is a single byte of binary data. Use the chr( function when working with text, the byte( function when working with binary data.
| 10.0 | Updated | Carried over from Panorama 6.0, but now returns a binary value instead of a text value. |
