longlongword(
NUMBER
The longlongword( function converts a number into a 64 bit longword (8 bytes) of binary data (see Binary Data).
number – is the value that you want to convert into a binary number.
This function converts a number into a 64 bit longword (8 bytes) of binary data (see Binary Data).
Error Messages
longlongword( function requires a numeric parameter. – Only numbers can be converted to binary, not text or other binary data.
10.0 | New | 64 bit support is new in this version. |
