false(
The false( function returns false.
This function always returns false.
false() ☞ 0
0
- and -- returns true if both operands are true.
- not -- reverses a boolean value.
- not( -- reverses a Boolean value
- or -- returns true if either operand is true, or false if both are false.
- switch( -- chooses from a list of values.
- true( -- returns true.
- xor -- returns true if one of the two parameters is true, false if neither or both are true.
