Using the run code command, Panorama code can be embedded into AppleScript code, allowing Panorama to be automated from other applications. Here is an AppleScript that makes Panorama the frontmost application, opens the Checkbook database in the Documents folder, and adds a new record.
tell application "PanoramaX"
    activate
    run code "openfile {~/Documents/Checkbook} addrecord"
end tell
This short example illustrates several important points. First of all, if you want Panorama to be the frontmost application, you must use the activate command. Otherwise Panorama will remain in the background.
Secondly, the Panorama code you want to run must be enclosed in double quote characters. This means that you cannot use the double quote characters for text constants in this code. Instead you can use { and } characters (as shown above), pipe characters, or smart quotes. See Quotes to learn how to use these different types of quotes. Or, you can prefix the quote characters with a backslash, like this:
    activate
    run code "openfile "~/Documents/Checkbook" addrecord"
end tell
The final point that this example illustrates is that you generally can’t make any assumptions about what state Panorama is in when the AppleScript code runs. Is the database you want to use the frontmost window, or even open? You can’t rely on that. To avoid unpleasant surprises, or errors, your code should usually start with statements that make sure that Panorama is in the state you want – that the database you need is open, the form you want is open, etc. Here’s an example of code that does not do that.
    activate
    run code "deleterecord"
end tell
This AppleScript will delete the current record of whatever database happens to be on top. Don’t write code like this!
Returning a Value to AppleScript
Use the SetAppleEventValue statement to return a value from Panorama to the AppleScript. This AppleScript finds out the number of selected records in the current database and displays that in a dialog.
    set recordCount to run code "setappleeventvalue info({selected})"
end tell
display dialog recordCount
Working with Lists
One of AppleScript’s powerful features is the List data type. Panorama does not directly support the list data type, but you can easily convert between Panorama text arrays and lists, and back again.
Here is an example that transfers a text array to an AppleScript variable and then converts that variable into a list.
    set databaseFields to run code "setappleeventvalue dbinfo({fields},{})"
end tell
set AppleScript's text item delimiters to return
set databaseFields to every text item of databaseFields
This can be rearranged into a simpler version:
    set databaseFields to every text item of (run code "setappleeventvalue dbinfo({fields},{})")
end tell
Error Handling
Usually when an error occurs in a Panorama program, Panorama stops and displays an alert. If the program is embedded in an AppleScript, however, this does not happen. Instead, the error is returned back to AppleScript.
If you don’t want the error to propagate back to AppleScript, use if error, try/catch or onerror to trap and handle the error in Panorama. See Error Handling to learn more about these techniques.
Calling a Subroutine
You don’t need to include all of the code you need to run in the AppleScript itself, instead you can use the call or farcall statements to invoke procedures you have already put in the database. This example opens a checkbook database (or brings it to the front if it is already open) and calls the ExportLastMonth procedure.
    activate
    run code "openfile "~/Documents/Checkbook" call ExportLastMonth"
end tell
If you know a database is already open, you can use the farcall statement to invoke subroutines in that database without first bringing that database to the front, like this:
    run code "farcall {Checkbook},ExportLastMonth"
end tell
A potential problem with this technique is that the ExportLastMonth subroutine may rely on the Checkbook database being the topmost database – in fact it probably does rely on that. If it is not currently the topmost database, errors will occur (since the correct fields are not available, etc.) You can fix this by adding the topdatawindow statement to the top of any procedure that is called by farcall, as shown here:
topdatawindow info("proceduredatabase")
... rest of procedure
Or, if you need the database to be active but not necessarily visible, you can use the setactivedatabase statement.
setactivedatabase info("proceduredatabase")
By the way, the info(“proceduredatabase”) function returns the name of the database that contains the procedure code, even if that isn’t currently the active database.
10.1NewNew in this version.
