unixshellstring(
TEXT
The unixshellstring( function encodes text for use as a parameter to a unix shell command.
text – text to be encoded.
This function encodes text for use as a parameter to a unix shell command. Any special characters in the text are “escaped” by putting a backslash () in front of the special character.
unixshellstring("Panorama's $Shell /Test Strin#g!?")
    ☞ Panorama\'s\ \$Shell\ /Test\ Strin\#g\!\?
Note: This function has special treatment for the tilde (~) character. If the tilde is the first character of the text, it is not escaped. A tilde in another other position is escaped.
10.2UpdatedThis function doesn't escape the ~ symbol if it is the first character in the string.
