The javascriptstring( function converts a text string into a JavaScript string
This function has one parameter:string – text to convert into a JavaScript string.
This function converts text into a JavaScript string literal. To do this the function surrounds the text with double quote characters, and escapes any double quote and/or backslash characters within the text. It also converts carriage returns, line feeds, tabs and vertical tabs into the corresponding backslash equivalents.
javascriptstring({P\E "ratio"}) ☞ "P\\E \"ratio\""
