javascriptconstant(
VALUE
The javascriptconstant( function converts an expression into a JavaScript literal.
value – value to be encoded. This value may be text, in which case it will be properly quoted. Any special characters in the text will be escaped. The value may also be numeric, in which case it is passed thru “as-is”.
This function converts an expression into a JavaScript literal. If the formula value is text, the function surrounds the text with double quote characters, and escapes any double quote and/or backslash characters within the text. If the value is numeric it is simply converted to text.
javascriptconstant("Hello World") ☞ "Hello World"
javascriptconstant("He said ""hello"" then he left") ☞ "He said \“hello\“ then he left"
javascriptconstant(3264) ☞ 3264
- applescriptconstant( -- converts an expression into an AppleScript literal.
- hiddenappcount( -- returns the number of apps that are currently hidden.
- javascriptstring( -- converts a text string into a JavaScript string
- nothiddenappcount( -- returns the number of apps that are currently not hidden.
- perlconstant( -- encodes text for use as a constant in a Perl program.
- phpconstant( -- encodes text for use as a contant in a php program.
- pythonconstant( -- encodes text for use as a constant in a python program.
- rubyconstant( -- encodes a value for use as a constant in a Ruby program.
- runningappinfo( -- returns information about applications that are currently running on this computer.
- Scripting Panorama X with AppleScript -- embedding Panorama code into AppleScript (allowing Panorama to be controlled from other programs).
- unhideotherapplications -- unhides all other applications, making all running applications visible.
- unixshellstring( -- encodes text for use as a parameter to a unix shell command.
