perl(
SOURCE
The perl( function executes a perl program and returns the result (stdout).
source – Perl program (source code). Note: It is very convenient to use “pipe” delimiters for the source code parameter, for example |||code|||
. This eliminates needing to worry about the delimiters appearing in the source code itself.
This function executes Perl source code and returns the result. Here is a simple example.
perl({print "Hello World"."\n".$«timepattern(now(),"hh:mm:ss am/pm")»$}) ☞ Hello World
4:47:26 PM
WARNING: Apple has stopped providing Perl with macOS. If you are using a recent version of macOS, you will have to install Perl yourself. See Scripting Language Configuration to learn how to do this.
Panorama formulas can be embedded in the Perl source code using special tags. To embed a Panorama formula use
$«formula»$
The formulas are calculated in advance, then embedded into the source code as constants. For example, the formula $«2*3»$
will be embedded into the program as 6
. The formula $«upper("hello world")»$
will be embedded as 'HELLO WORLD'
. Note: You can embed database fields, global variables, fileglobal variables, and windowglobal variables into the formula, but local variables will not work. (You can, however, use local variables with the perl statement.)
In the case of text formulas any special characters will be encoded as necessary for a proper Perl constant. For example the formula $«{"}»$
will be embedded as '\x23'
To embed a Panorama formula with no quotes or translation use
^«formula»^
- applescript -- executes an AppleScript.
- applescript( -- executes AppleScript source code and returns the result.
- blindposixscript( -- executes a POSIX shell script using NSTask and returns the process id.
- executeapplescript -- compiles and runs an AppleScript.
- executeperlscript -- executes Perl code.
- executesudounix -- executes a UNIX shell command using *sudo* (root) privileges.
- executeunix -- executes a UNIX shell command.
- perl -- executes a Perl script (program).
- php -- executes a PHP script (program).
- php( -- executes a PHP program and returns the result.
- posixscript( -- executes a POSIX shell script using NSTask and returns the result.
- posixtask( -- executes a POSIX shell script in the background using NSTask.
- python -- executes a Python script (program).
- python( -- executes a python program and returns the result (stdout).
- ruby -- executes a Ruby script (program).
- ruby( -- executes a ruby program and returns the result (stdout).
- scriptbglog -- specifies a path/file for output from STDOUT from embedded programs run in the background (Perl, Ruby, Python, PHP).
- Scripting Language Configuration -- configuring the scripting languages available to Panorama (Perl, PHP, Python and Ruby).
- scripttimeout -- sets the maximum runtime allowed for an embedded program (AppleScript, ShellScript, Perl, Ruby or Python).
- shellscript -- executes a UNIX shell script.
- shellscript( -- executes a UNIX shell script and returns the result.
- usebashprofile -- grabs the search path from the `.Bash_profile` file in the user's home folder, so that these paths will be used by scripting languages (*Ruby, Python*, etc.).
- xcallbackurl -- performs an action in another application using the x-callback-url mechanism.
