noactionmenu(
The noactionmenu( function suppresses the Action menu.
This function suppresses the Action menu. It can only be used in the second parameter of the filemenubar, globalmenubar or windowmenubar functions. This example will build a menu bar with the menus Panorama, File, Edit, Orders, Window and Help, but no Action menu.
filemenubar "basic",
menu("Orders")+
menuitem("New Order")+
menuitem("Print Order")+
menuitem("Ship Order")+
noactionmenu()
Note: Here is another way to build the same menus without the noactionmenu( function.
filemenubar "file -action",
menu("Orders")+
- Action Menu -- simple way to create your own menu items.
- arraymenuitems( -- converts a carriage return delimited array into a series of menu items.
- checkedarraymenuitems( -- converts a carriage return delimited array into a series of menu items, some of which may be checked.
- checkedmenuitem( -- creates a single menu item with an optional checkmark.
- Construct Menu -- used to automatically construct complex form applications, including calendars, lists, mailing labels, and more.
- Edit Menu -- edit text and data, to search (and replace), and to undo and recent actions.
- Field Menu -- manages fields, including adding and removing fields, setting field properties, sorting, morphing, hiding and showing.
- File Menu -- create, locate, open, close and save databases, import and export text, printing.
- filemenubar -- creates a custom menu bar or context menu for the current database (see Custom Menus).
- globalmenubar -- creates a custom menu bar or context menu for all windows (intended only for internal use by ProVUE Development).
- Help Menu -- contains items that will help you learn and use Panorama.
- LMSL -- is the specification language for Live Menus.
- menu( -- creates a menu (see Custom Menus).
- menuitem( -- creates a single menu item (see Custom Menus).
- menuitems( -- converts a semicolon separated array into a live menu specification.
- Menus -- overview of Panorama X menu bars.
- menuseparator( -- generates a menu item separator
- noinstrumentationmenu( -- supresses the *Instrumentation* menu.
- nowizardmenu( -- suppresses the *Wizards* menu.
- Objects Menu -- used to select, modify and arrange graphics objects in a form.
- Panorama Menu -- get and set information about Panorama itself, including the version number, licensing information, and memory usage.
- popupatmouse -- displays a pop-up menu at the current mouse location.
- popupbelowbutton -- displays a pop-up menu in response to clicking on a button.
- popupclick -- displays a pop-up menu at the current mouse location.
- popupdoublefieldchoices -- displays a pop-up menu listing values in a specified field, with submenus containing values from a second field.
- popupfieldchoices -- displays a pop-up menu listing values in a specified field.
- Records Menu -- add and remove database records.
- Search Menu -- is used search for data, to select records, and to find and replace text within the current field.
- standardactionmenu( -- generates a Custom Menu specification for Panorama's standard Action menu.
- standardclassicsetupmenu( -- generates a customizable Custom Menu specification for Panorama's classic Setup menu.
- standardconstructgraphicsmenu( -- generates a Custom Menu specification for Panorama’s standard Construct menu (in Graphics Mode).
- standardeditmenu( -- generates a customizable Custom Menu specification for Panorama's standard Edit menu.
- standardfieldsmenu( -- generates a customizable Custom Menu specification for Panorama's standard Fields menu.
- standardfilemenu( -- generates a customizable Custom Menu specification for Panorama's standard File menu.
- standardhelpmenu( -- generates a customizable Custom Menu specification for Panorama's standard Help menu.
- standardinstrumentationmenu( -- generates a Custom Menu specification for Panorama’s standard Instrumentation menu.
- standardpanoramamenu( -- generates a Custom Menu specification for Panorama's standard Panorama menu.
- standardrecordsmenu( -- generates a customizable Custom Menu specification for Panorama's standard Records menu.
- standardsearchmenu( -- generates a customizable Custom Menu specification for Panorama's standard Search menu.
- standardsetupmenu( -- generates a customizable Custom Menu specification for Panorama's standard Setup menu.
- standardsortmenu( -- generates a customizable Custom Menu specification for Panorama's standard Sort menu.
- standardtextmenu( -- generates a customizable Custom Menu specification for Panorama's standard Text menu.
- standardviewmenu( -- generates a Custom Menu specification for Panorama's standard View menu.
- standardwindowmenu( -- generates a customizable Custom Menu specification for Panorama's standard Window menu.
- submenu( -- creates a submenu (see Custom Menus).
- Window Menu -- controls the back to front arrangement of windows, it allows you to hide, show, or customize the toolbar (see Toolbar, and allows you minimize or zoom the window to full screen.
- windowmenubar -- creates a custom menu bar or context menu for the current window (see Custom Menus).
