submenu(
TITLE
OPTION
VALUE
The submenu( function creates a submenu (see Custom Menus).
title – title of the menu.
option – one or more options that modify the menu. See below for descriptions of each option. The option name can be specified in either upper or lower case.
value – the value for the option specified in the previous parameter.
This function creates a menu (see Custom Menus) that can later be attached to a menu item as a submenu. In its simplest form, the function has a single parameter, the title of the menu item. This example creates a submenu named Shippers.
submenu("Shippers")+
    menuitem("Airborne")+
    menuitem("Fedex")+
    menuitem("US Postal Service")+
    menuitem("UPS")
Because it is a submenu, the Shippers menu does not appear in the menu bar. However, it can be attached as a submenu to a menu item in a subsequent menu.
menuitem("Ship Via","SUBMENU","Shippers")
That’s all there is to it. When the menu is pulled down, Shippers will automatically appear as a submenu to the Ship Via menu item.
In addition to the title parameter, you can also specify one or more option/value pairs that modify the menu appearance, like this:
menuitem(title,option1,value1,option2,value2,option3,value3)
Here is an example that creates an Oceans submenu that is displayed in blue, using the font Futura Condensed.
submenu("Oceans","FONT","Futura Condensed","COLOR","0000FF")+
    menuitem("Atlantic")+
    menuitem("Pacific")+
    menuitem("Indian")
For more information about menu appearance options see the menu( function.
10.0UpdatedCarried over from Panorama 6.0, but with new options for setting font, text size, color and style.
