nowizardmenu(
The nowizardmenu( function suppresses the Wizards menu.
This function suppresses the Wizards menu. It can only be used in the second parameter of the filemenubar, globalmenubar or windowmenubar functions. This example will build a menu bar with the menus Panorama, File, Edit, Build, Action, Window and Help, but no Wizards menu.
filemenubar "basic",
    menu("Orders")+
        menuitem("New Order")+
        menuitem("Print Order")+
        menuitem("Ship Order")+
    nowizardmenu()
Note: Here is another way to build the same menus without the nowizardmenu( function.
filemenubar "file -wizards",
    menu("Orders")+
